Hot Water Pipe Issue
To investigate, you may need to pull up the carpeting. If you do not see moisture, then take a sheet of plastic about 4 feet square and tape it on all 4 sides to the floor where it is unusually warm or where you suspect a leak may be. Two days later if not more quickly, moisture under the plastic will confirm the leak.
If your apartment is "ground floor" with part of the walls below ground level, your apartment will likely be more humid than the upstairs apartments all of the time. Warm summer air against the not so warm walls (and also floor) leads to increased humidity if not some condensation.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
