Hot Water Pipe Frozen - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-10-2013, 11:11 AM   #1
Angry
Hot water pipe frozen
My hot water pipe is frozen. The main pipes/feeds to the house are on the outside of the house, in a little area with the hot water tank and heating unit, since they both run as one and both work off of kerosene (we have baseboard heating). The cold water, about five minutes ago, just kicked back on, so I left the hot water faucets on to help relieve that pressure and help it thaw out. I was wondering if there was a way to thaw out the pipe in a timely manner. I keep reading things about using a blowdryer, but they are all mixed discussions (they are good, they are not good). We've used one before, but last time, something in the house burst. I don't know what I should do this time in order to help this issue.
UPDATE: Problem solved! Everything is back to normal. Gotta insulate the boiler area better.
d_heath is offline   Reply With Quote
Old 02-10-2013, 03:01 PM   #2
For future reference, a blow dryer will work if it's only a small area that's frozen. There are also heat guns available, which are basically like a blow dryer but much hotter and much more expensive. The best way to stop freezing is to keep the pipes out of the elements - wind is your worst enemy. Pipe insulation will help a little, but you really want to close in the area where the pipes are.
Know also that in the earlier example you cited, the act of thawing out the pipe did not cause the burst. The freeze itself is what burst the pipe, it just didn't become evident until it thawed and the water started flowing out of it.
percygreen is offline   Reply With Quote
Tags
frozen pipes , hot water pipes , pipes , plumbing problem
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Do I need a ground rod to replace copper water pipe mfkcbk Electrical 10 11-11-2010 04:03 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Change in pipe diameter at water heater blacksheiladog Plumbing 2 03-06-2009 12:12 PM
