Hot Water Overflow Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-14-2011, 11:59 PM   #1
I have a 140L Copperflow Electric Heat Exchange hot water system, model 2895.
It is dated 02/2004.
In the last few weeks the 'Overflow' has gradually increased its leaking rate, to near a constant flow. (There is a mains tap before the HPNR valve and HWS so currently I am just turning this water feed on and off when requiring hot water.)
After various consultations, I decided to replace the 'RMC' HPNR valve, (around $130).
The leak now seems worse than ever!
Is there another possible cause to the leak?
Is the new HPNR valve likely to be faulty?
Thanks for any interest.
Hot Water is offline   Reply With Quote
Old 08-15-2011, 06:13 AM   #2
DIY staff
Rewards Points: 7,174
Does this system have an expansion tank? If so see if it is defective.
Is there a pressure regulator /back flow/fast fill valve? Check to see if the valve is on fast fill instead of the normal operating position.
Hopefully a boiler guy will spot this one---Mike----
Old 08-15-2011, 06:42 AM   #3
Thanks Mike
No expansion tank, pressure regulator, back flow or fast fill valve -
it is a coil system that is immersed in heated water. The High Pressure Non Return valve is really two valves; for the heated water (not under pressure) and the for coil water (under mains pressure).
I now believe the coils are leaking into the heated reservoir surrounding them.
This causes the reservoir overflow excess leakage.
Simply, new system required.
Cheers for your time though.
The Following User Says Thank You to Hot Water For This Useful Post:
oh'mike (08-15-2011)
Tags
copperflow , hotwater , hpnr , overflow , rmc
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water leak, over 1 gallon every 5 minutes. carl1864 Plumbing 13 01-15-2010 12:31 PM
Water Leak swoop Plumbing 2 01-14-2010 06:02 PM
Leak on gas heater water line? darsunt Plumbing 3 04-16-2008 03:57 PM
