Hot Water Out Of Heater But No Pressure To Taps - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-13-2011, 10:06 AM   #1
Hot water out of heater but no pressure to taps
Hi all,
I woke up this morning(-30C) to no hot water pressure out of any taps.
When I crack the hot water union at the top of the heater there is hot water. The cold water pressure seems to be good coming into the heater as well.
I am not sure the next step in troubleshooting is? Do I have to go under my modular and follow the hot water line to see where it stops? Is there a better way(inside warm house) to troubleshoot?
Any and all suggestions comments are most welcome! The sooner I can fix this the sooner I can get to work!
Thanks a lot!
treefort is offline   Reply With Quote
Old 01-13-2011, 10:48 AM   #2
It is definitely frozen or plugged somewhere down the line as I disconnected the hot coming out the heater and there is plenty of hot water pressure coming out into my bucket. So, I guess I better suit up and crawl underneath to see what is going on.
Old 01-13-2011, 11:21 AM   #3
DIY staff
Rewards Points: 7,174
Sounds like a frozen pipe,for sure---If you must leave the house it would be a good idea to shut off the hot water feed line and turn the heater to 'pilot' while you are out---
I've seen some horrific messes when a broken fitting thawed out.--Mike--
treefort (01-13-2011)
Old 01-13-2011, 04:30 PM   #4
Rewards Points: 352
A couple of 100 watt flood light or heat lamps in a clamp on holder in a sealed crawl usually thaws everything in less than 24 hours. leave all hot water faucets cracked open a little so you know when it opens up. Don't start no fires with the lamps. Listen for running water after the thaw that indicates a broken fitting or pipe
plumberinlaw is offline   Reply With Quote
Old 01-13-2011, 05:44 PM   #5
Finally had a good reason to get a good infrared heater so I bought one, and bought some safe for environment methanol. I cranked the heat, poured some methanol down the lines, and set the heater up under the trailer. And then went to get a Herman Nelson, but by the time I got back the methanol had dropped and broke the hydrate. Didn't even need the 165,000 BTUs!
Thanks again for chipping in oh'mike.
The Following User Says Thank You to treefort For This Useful Post:
oh'mike (01-13-2011)
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
Low water pressure in kitchen faucet after replacing water heater SusanonDaffodil Plumbing 8 01-27-2011 02:28 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 06:40 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
