Hot Water Only... - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-19-2009, 07:11 PM   #1
Post
Hot water only...
We are on a well and for the past couple days our water temp ranges from warm, to hot, to hotter (depending on how long we let it run.) The water temp is the same for the faucets in all areas of the house as well as the washer and toilets. The water pressure is fine all around. Any help is appreciated.
jcro17 is offline   Reply With Quote
Old 09-19-2009, 07:31 PM   #2
And this is new? How long does it take to get hot? Doesn't it always take a few seconds to get hot?
mics_54 is offline   Reply With Quote
Old 09-19-2009, 08:18 PM   #3
I must not have explained very well. We have no cold/cool water. Upon turing on the faucet we get bath water temperature which progressively gets hotter. So much that you have a max of about 10 minutes in the shower before it gets too hot. No neighbors are having similar problems.
Old 09-19-2009, 10:44 PM   #4
Rewards Points: 1,440
Are you getting steam or unusual pressure of water out the hot water faucets? If so turn the water heater controls to off now. Leave a faucet open until the pressure returns to normal. The water heater is malfunctioning and could explode!
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
