Hot Water Not Circulating - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-08-2009, 12:28 PM   #1
hot water not circulating
We just recently changed the setup of one of our hot water system in our hotel (not sure why), and since we changed it, we can't seem to get the hot water to circulate. The temp on both w/h's is at the hottest temp as well and the pump is working.
Before we changed it, both hot waters fed into the main line that goes to all the rooms. Now we have it setup where one of the w/h feeds the other one and then the one it feeds to goes into the main line. Also, the circulator pump is at the end of the recirculating system. Also, there is alot of water pressure coming off the cold water line that feeds into the first hot water compared to the pressure coming from the recirculating line. I'm not sure if the pressure from the cold water line is blocking the pressure from the recirculating line?
Any ideas why the hot water stopped recirculating?
rpatel18 is offline   Reply With Quote
Old 12-08-2009, 01:06 PM   #2
the Musigician
DangerMouse's Avatar
did you replace the WHs? if not, it's likely the first is gunked up?
DM
Old 12-08-2009, 02:28 PM   #3
NOJ
problem solver
I've come across it many times. check ur gate valves if u have a dropped gate it won't let the water circulate
NOJ is offline   Reply With Quote
Old 12-08-2009, 02:33 PM   #4
Not trying to be facetious: Make sure the arrows on the circulator and the check valve are both pointing in the same direction.
Ishmael is offline   Reply With Quote
Old 12-08-2009, 02:54 PM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
Make sure the pump impeller is spinning in the proper direction. Make sure any backflow preventers are operating properly.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 04:01 PM
Possible to convert hot air heat to water circulating radiators djtjak43 HVAC 3 01-11-2009 08:58 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
