Old 06-22-2009, 04:07 PM   #1
Hot water mystery
Hi,
I redid both bathrooms in the house with brand new Moen-Adler faucets all the way around and a new water heater and did not change up the copper in the walls at all really, just the connectors to the new faucets..
Anyway, when I turn on the shower upstairs to hot I just get luke warm water, but if I turn on the tub and sink at the same time the shower gets hot like it should. For this reason I did not think it was a matter of adjusting the posi-temp in the faucet and that didn't help anyway.
Is this indicitive of anything familiar to any pros out there?
TIA
Steven
StevenW is offline   Reply With Quote
Old 06-23-2009, 07:17 AM   #2
Hot water mystery
Is the valve installed correctly(usually have an 'up' arrow), shutoff valves all fully open??? Pressure balance valves are very sensitive to pressure differences. Which is how they work.
Old 06-23-2009, 12:08 PM   #3
DIY'r
ScottR's Avatar
Hot water mystery
If the lines weren't flushed after the HWH replacement, you may have solder and some other foreign matter clogging the shower valve's hot side. That would throw the pressure out of whack, too. (Maybe.)
Could also be the hot water limit setting on the valve is set way too low.
ScottR is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Tankless or tank, but not both gp_wa Electrical 43 10-15-2008 11:08 PM
