Hot Water Murky For Tap - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2009, 11:31 AM   #1
hot water murky for tap
When I turn on faucet hot water comes out murky white. How do you get the air out of the hot water tank?
Fixitfredy is offline   Reply With Quote
Old 02-08-2009, 12:12 PM   #2
Rewards Points: 2,906
Normally, the hot water outlet will be right at the top of the hot water heater, so drawing hot water from the tank SHOULD also remove any trapped air.
I'd run some water out of the tank's drain valve and see if it's also murky white.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
