Hot Water Mixing Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-26-2013, 06:41 PM   #1
Rewards Points: 121
Hot water mixing valve
I need to change one of these, do these valves vary in size, would i beable to just unscrew the old or is there some plumbing involved, and is there any reason to turn the hot water tank off.
rick31797 is offline   Reply With Quote
Old 03-26-2013, 06:58 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 562
They're all different. Can you put up some pictures?
Old 03-26-2013, 09:38 PM   #3
Rewards Points: 252
Is this on your hwh, sink, shower, etc. Like E said they are all different. Please post some pics.
jmon is online now   Reply With Quote
Old 03-27-2013, 06:33 AM   #4
Rewards Points: 121
valve
This is on the Gas Hot water tank.
Old 03-27-2013, 09:58 AM   #5
Rewards Points: 252
Looks like they are all unions to me. Your lucky. Should be able to unscrew old one (ccw) screw on new one. Use 2 big wrenches or channel locks just in case they are tight. Even though u will have water off and faucet open, there still will be some water that will come out, just be prepared for that. Have some rags, bucket or towels ready. Let's see what the pro's say.
Old 03-27-2013, 10:06 AM   #6
Rewards Points: 121
valve
i just hoping the new mixing valve is close to the old and the distance between the unions will work, or i will have to cut some pipe.. the two copper pipes coming out of the heater are fixed, i dont think i will get much movement.
Old 03-27-2013, 10:10 AM   #7
Rewards Points: 13,456
Should be a name on that valve some place.
Looks like a Honeywell.
http://www.bing.com/shopping/honeywe...M=EGCA&lppc=16
Old 03-27-2013, 10:10 AM   #8
Rewards Points: 252
Exactly, I c what u mean. Hopefully u can find one the same size as that one. If not, some plumbing maybe required to make new one fit. U should have a little play there, but it doesn't look like a lot. Like Joe recommends above, c if there is a name or number on old one - go from there.
Old 03-27-2013, 11:35 AM   #9
Rewards Points: 121
valve
I will take it off, and see if there is a name , maybe i can match it up... In Canada its code to have a mixing valve...Thanks for your help.
Old 03-27-2013, 11:45 AM   #10
Rewards Points: 252
Your welcome. Hope everything works out for u.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
No cold water out of mixing valve? apex_predetor Plumbing 10 03-17-2010 04:25 PM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 10:01 PM
Cold water not working in washing machine. 68MHJCs Appliances 15 01-20-2009 05:18 AM
