Hot Water Missing In Half The House - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2014, 11:22 AM   #1
Rewards Points: 18
Hot water missing in half the house
I live in Toronto, where is it currently -20C (-4F), and it feels even colder with the wind chill. Not sure if that's a factor here.
This morning, I noticed that I had no hot water in half the house. In the upstairs bathroom, main floor laundry, and basement bathroom, specifically, I have no hot water. Not even a trickle. These three rooms are situated directly above each other.
Fifteen feet away, I have my main floor kitchen directly above my basement kitchen and basement laundry room - I have full hot water in these rooms.
Cold water is available everywhere at normal pressure.
Thinking that it might be an air lock, I disconnected my main floor laundry machine, and I connected the cold faucet directly to the hot faucet. I opened up the hot and then the cold to push back the air. I tried this four times, up to 30 seconds each time, and it had no noticeable result, except I could occasionally hear air from my second floor bathroom faucet when the hot water valve was opened there after each time I tried.
I'm not sure what types of pipes I have in the house. Everything was working fine last night. My basement is finished.
Any ideas? Thanks team.
TorontoMike is offline   Reply With Quote
Old 01-03-2014, 11:53 AM   #2
Rewards Points: 144
Being how everything was working fine and it's currently -20 degrees right now at your location, i'm guessing you have a frozen hot water line somewhere that's feeding the areas you describe in your post. It may be something else, but a frozen pipe is the most logical explanation at this point. Stay tuned, others will be along shortly with more advice/ideas. Thanks.
jmon is offline   Reply With Quote
The Following 2 Users Say Thank You to jmon For This Useful Post:
Gymschu (01-03-2014), TorontoMike (01-04-2014)
Old 01-03-2014, 12:17 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Ayuh,... I agree, there's No doubt the hot water line is frozen,....
It's time to start Diggin' to see what's up,...
The Following User Says Thank You to Bondo For This Useful Post:
Old 01-03-2014, 12:24 PM   #4
Rewards Points: 18
But it must be a frozen hot water line somewhere inside the house if half the house is working, right?
Also, why would a hot water line freeze before a cold water line? I would imagine the two lines run in parallel.
Old 01-03-2014, 12:38 PM   #5
Rewards Points: 6
Could be a hot water line run in an outside wall that wasn't fully covered with insulation while the cold line was.
Dan
djlandkpl is offline   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
Old 01-03-2014, 12:50 PM   #6
Rewards Points: 77
Sounds like a pipe on an outside wall froze up. Someplace I have heard hot water lines freeze faster then cold. I am not sure if that is true or not.
cyberknight is offline   Reply With Quote
The Following 2 Users Say Thank You to cyberknight For This Useful Post:
del schisler (01-03-2014), TorontoMike (01-04-2014)
Old 01-03-2014, 01:13 PM   #7
Rewards Points: 144
Start by narrowing your search for a common hot water line that is feeding these areas you describe above. As others have suggested, maybe in an outside wall somewhere. That is more than likely where your freeze up is located. Warm up that pipe safely with a hair dryer, light bulb, or some heat tape. Just a thought.
Without getting into the whole science of it, it is possible that under certain conditions hot water can freeze before cold water. You can google it when you have time. More than likely, one was probably insulated better than the other.
The main issue is, you want to find where it's frozen and get it thawed before it causes damage to the pipe and possibly your house.
The Following User Says Thank You to jmon For This Useful Post:
Old 01-03-2014, 01:31 PM   #8
joed's Avatar
Rewards Points: 11,590
I saw one that froze because the water line ran above fart fan pipe. There was no insulation and the cold air came in the vent pipe and froze the water line above it. When it was thaw there was a flood as pipe had split.
Old 01-03-2014, 01:56 PM   #9
Rewards Points: 18
I'm not home, but a plumber is there with my wife. Apparently he has a machine that passes electrical current through the pipes and will heat them up. The problem is that we apparently must have some plastic pipes somewhere (this is news to me!), because it's not working. Right now we cranked the thermostat for the whole house and we have a space heater blasting at area where the problem likely is.
The Following 2 Users Say Thank You to TorontoMike For This Useful Post:
bbo (01-03-2014), jmon (01-03-2014)
Old 01-03-2014, 02:26 PM   #10
bbo
also of note is having insulation on the wrong side of the pipe. that effectively keeps the heat from the pipe and keeps the cold on it.
good luck. I remember in my old house when a discharge pipe for sump froze up. it was more time effective to cut that plastic pipe and clean it out than it was to wait for it to melt enough.
bbo is offline   Reply With Quote
The Following User Says Thank You to bbo For This Useful Post:
Old 01-03-2014, 03:30 PM   #11
Rewards Points: 18
Would it be beneficial to pour very hot water into an open hot water faucet?
Old 01-03-2014, 03:54 PM   #12
I remember living in older homes when it got this cold we were advised to keep the tap slightly open all night for a constant drip
Could be someone got up in the night and used the cold water, as in a flush, ?
creeper is offline   Reply With Quote
The Following User Says Thank You to creeper For This Useful Post:
Old 01-03-2014, 03:57 PM   #13
Rewards Points: 18
Maybe. But we are having no problems with the cold water. Only a hot water line is frozen somewhere. Someone getting up in the middle of the night and running water would have probably helped!
In the future, we will definitely keep a tap open during cold nights! Right now, I just need to get the hot water flowing again.
Old 01-03-2014, 04:03 PM   #14
Exactly... since the cold was used it didn't have a chance to freeze up.
You only need to keep it open a dribble. Good luck, warmer weather is coming
Old 01-03-2014, 04:23 PM   #15
Rewards Points: 1,700
Good luck hope your pipe hasn't broken.
The Following User Says Thank You to Ghostmaker For This Useful Post:
water main coming into the house? USNrider Plumbing 11 04-15-2013 07:04 AM
Roofing only half of the house annabruen Roofing/Siding 3 12-20-2011 09:36 AM
Anoying sound in house water pipes when sprinklers are ON gante Plumbing 1 06-07-2010 07:04 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
