Hot Water Leak Under Slab - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-07-2009, 02:36 PM   #1
Hot water leak under slab
I've got a hot water leak under my c.1955 slab. My oil burner kickes on every 60-70 minutes and you can hear the pipes "whining" when you're in the bathroom. When I turn off the hot supply, the "whining" stops and the leak detector stops on the meter.
You can feel the warmth from the pipe's path under foot and it takes awhile for the slab to cool down once the water supply is cut. My question is: Does it stand to reason that the leaking area would be the first to get warm? I bought an infrared thermometer and I was hoping to pinpoint the leak site before I tear up my hardwood floor. There is absolutely no hint of moisture in the area I am targeting.
Thanks,
Jon
Johnnoh is offline   Reply With Quote
Old 07-07-2009, 09:00 PM   #2
Rewards Points: 1,514
This is a good guess but not foolproof.
Since you can feel the path of the pipe once it heats up, try this. Turn the water back on but don't use any hot water for several hours. Feel for the warm path and where the path ends is probably where the leak is. (Hot water won't progress past that point when none is being used.)
Old 07-08-2009, 10:53 AM   #3
Thanks Allan!
Does anyone know if a Stethoscope might help? It has to go through a 4" slab.
Jon
Old 02-16-2015, 11:15 AM   #4
Rewards Points: 2
I don't think the stethoscope is going to be enough here.
jeremyjackson is offline   Reply With Quote
Old 02-16-2015, 12:29 PM   #5
Rewards Points: 13,738
Not going to do much good location that one leak.
By now that old plumbing is paper thin and needs to be rerouted through the walls or over head.
Old 02-16-2015, 05:23 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,368
Ayuh,.... After playin' with my point, 'n shoot temp sensor on my radiant floor, I'm thinkin' you oughta be able to find yer leak, within' a foot or two,....
There should be a Hot line right to the leak, 'n then spreadin' lower heat,...
or heat goin' wherever it's perkin' into the soil,...
Bondo is online now   Reply With Quote
Old 02-16-2015, 08:28 PM   #7
Rewards Points: 1,956
Been there done that didn't work. You would need a thermal image camera.
The Following User Says Thank You to Ghostmaker For This Useful Post:
mj12 (02-17-2015)
Old 02-17-2015, 01:23 AM   #8
Homerepairguy's Avatar
Rewards Points: 998
When there was a hot water leak under our concrete slab, I replaced it with PEX in the attic. That worked since it never freezes in our area. Was a LOT easier than trying to find the leak under the slab, breaking through 4 inches of concrete and disrupting our home for a long period.
Besides, even if the leak is found and repaired, my guess is that another leak will probably happen again someplace else within a couple of years. Because the copper hot water line under the slab is now marginal IMO.
HRG
Homerepairguy is offline   Reply With Quote
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
water leak! copperdude Plumbing 5 06-13-2009 08:07 PM
$$$$ water leak fix? greenhorn_ltl Plumbing 6 01-14-2009 09:10 AM
Hot water heater leak? chrisintroy Plumbing 3 02-27-2006 09:13 AM
Hot water heater leak? ddasher8 Plumbing 1 07-03-2005 05:00 AM
