Old 09-11-2012, 12:56 PM   #1
hot water leak
why is my master bath and bedroom floor warm nad warm water is coming from the cold faucet
sharod2 is offline   Reply With Quote
Old 09-11-2012, 05:03 PM   #2
hot water leak
Done any plumbing around the house lately???
Canarywood1 is offline   Reply With Quote
Old 09-11-2012, 08:07 PM   #3
Bombastic Idiot
notmrjohn's Avatar
hot water leak
Where is the house? What kind of weather are you having? How long has this been going on? What is the foundation? Where in relation to outside walls is the bathroom? Which wall of the bathroom is the faucet?
Water is always warmer here in summer because reservoirs, treatment and storage tanks, ground and pipes in it are warmer. Slab foundations are warmer especially near perimeter. Slab can then warm water, conversely slab directly over warm supply line can be warmer. Pipes in exterior walls, such as at bath tub are warmer. Pipes in crawl space are warmer. This can all happen gradually as weather warms, especially slab warming. You might not really notice it, then one day you do.
Winter time the opposite happens, cold floor, hot water not hot enough.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Fixed water leak now low pressure whitecrow Plumbing 15 08-13-2011 12:36 PM
Copper Pipe Leak Caused by Hard Water? Asathd Plumbing 20 07-09-2011 10:06 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 10:24 PM
