Hot Water Knob Wont Turn All The Way - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-26-2008, 09:38 PM   #1
hot water knob wont turn all the way
Hello i'm new to this forum and to doing home improvement things myself.
i have an older 2 knob sink.. here lately the hot water knob wont turn but just a little bit and barely let any hot water out.. when i compare it and the cold water knob the hot water knob when completely shut off is still screwed most of the way out of the sink and the cold water knob screws all the way down to the sink when its closed. so when i turn the hot water on it only takes the knob just a bit of a turn to already be all the way open, but only a trickle of water comes out.. i'm not sure if i'm explaining this clearly.. if you have any more questions i'll check this thread reglularly.
cloud is offline   Reply With Quote
Old 06-27-2008, 12:39 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
what type / brand of faucet is it?
Journeyman Plumber
Old 06-27-2008, 12:40 AM   #3
Registered User
Termite's Avatar
Sounds like it is time for a rebuild of the valve stem, or both of them while you're at it.
First, shut off the water supply to the faucet at the shutoff valves, or at the main shutoff if you don't have shutoffs under the sink.
Take the handle off. You'll have to figure this one out. There are many configurations on the market. Usually it involves screws of some sort, and it is done from above the counter.
Taking the handle off will expose the stem. It will be a brass or plastic cartridge. Some thead in, some just seat in there. That's what needs to be replaced or rebuilt. Before removing it, take note of how it is positioned. Some of the plastic ones have a specific orientation that must be matched when reinstalling new ones.
Take the stem(s) to a plumbing specialty store and ask what to do. They're not overly expensive. The box stores have some, but usually not the selection that plumbing supply stores do.
Old 06-27-2008, 04:34 AM   #4
Long-Time DIYer
Mike Swearingen's Avatar
And depending upon the type/brand, the hot water valve stem will be different than the cold water valve stem, so ask at the plumbing store.
Better yet, take them with you.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-27-2008, 09:19 PM   #5
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
Definitely take the old one with you. Here's a link to an article that might help:
http://ezinearticles.com/?Bathtub-Fa...ues&id=1249179
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 10:24 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 11:29 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 10:03 AM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 03:17 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
