Hot Water Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2012, 08:37 PM   #1
Hot water issue
Recently roughed in some plumbing for a bathroom. There was existing stems for the rough in so it was very simple. Once the plumbing was done we turned the water back on and we are now having major issues getting hot water to all the faucets and bathtubs. We can have hot water in one sink and ice cold coming out another. There is no telling which sink will get the hot water and which one wont, its bizarre. Anyone ever heard of such a problem or have any ideas on how to resolve it? I 'm interested if anyone knows anything about a vapor lock?
DP21 is offline   Reply With Quote
Old 02-02-2012, 08:45 PM   #2
Rewards Points: 582
need some pictures to see what you call simple....sounds like there is crossed water lines somewhere.....
The Following User Says Thank You to ben's plumbing For This Useful Post:
plummen (02-02-2012)
Old 02-02-2012, 08:57 PM   #3
No crossed lines, since there was an existing hot and cold stem already in. All I did was cut the pipe, put a T on and ran hot and cold for the shower and sink. I've done this before with no issues at another house. I can turn on the hot water at one sink, which runs cold, then turn the hot on at another sink and we then get hot at both sinks. Or I get hot water on the 2nd floor, but ice cold on the main floor or visa versa.
Old 02-02-2012, 09:10 PM   #4
GC/Master Plumber/Mech
Rewards Points: 560
Sure sounds like a cross somewhere.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-02-2012, 09:21 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 452
yep
Old 02-02-2012, 09:23 PM   #6
Plumber
Rewards Points: 452
do you have the cartridge in the shower valve?
Old 02-02-2012, 09:35 PM   #7
Holly cow, that's it!! Something so simple that I overlooked. Thanks a ton.
Old 02-02-2012, 09:40 PM   #8
Delta?
broox is offline   Reply With Quote
Old 02-02-2012, 10:06 PM   #9
Rewards Points: 560
It's still a cross connection
Old 02-02-2012, 10:18 PM   #10
Plumber
Rewards Points: 452
Shoulda gone moen
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 10:47 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Rheem water heater gas valve issue tsherv Plumbing 4 05-26-2009 10:38 AM
