Hot Water Is Hot Everywhere But The Tub !help! - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-22-2013, 09:34 PM   #1
Question
Hot water is hot everywhere but the tub !help!
Ok so ill try to make this as short as possible. I installed a new shower and tub, previous to that I couldn't fill my tub with hot water unless I filled it with the shower, if I used the faucet it would come out barely warm. Now I have replaced the copper tubbing valves etc. and neither the shower head or the faucet get hot unless I isolate the cold water than it comes out very hot. I tried cracking the cold water slowly and it goes from very hot to barely warm again. Any advice will help I have a oil boiler if that helps with the responses
Gooch9891 is offline   Reply With Quote
Old 03-22-2013, 09:39 PM   #2
Rewards Points: 6,652
Bad valve cartridge if single handle unit. Post a picture of the tub faucet.
Old 03-22-2013, 09:41 PM   #3
Roofmaster
Rewards Points: 2,210
This problem has been discussed a lot. You may want to search posts for no hot water. Are your other fixtures working properly? If they are, you probably have the anti-scald prevention feature set wrong on your fixture.
Old 03-22-2013, 09:47 PM   #4
Old 03-22-2013, 10:10 PM   #5
No wonder why it is not working, someone attached it to the ceiling. Turn off the water, then pull the cartridge. Have someone turn back on the water for hot, if you have a shut off for the hot & cold somewhere that you can get to. Otherwise, you need to install shut offs, so that it makes it easier when working on the tub, without having to shut off the whole house water supply.
I am going for a cartridge that is either installed wrong, or wrong one to begin with.
Old 03-22-2013, 10:29 PM   #6
The cartridge is installed properly thankfully I noticed it was labeled tub and shower and during this little project I installed some isolation points but I'm going to look into the cartridge maybe defective but I won't rule out operator error yet haha thanks for the help I'll post my results. Thanks for the input
Old 03-23-2013, 03:52 AM   #7
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
New tub and shower valve? Your hot limit is likely set incorrectly.
JDC is offline   Reply With Quote
Old 03-23-2013, 10:10 AM   #8
Roofmaster
There was a previous post where the whole fixture was installed sideways by a so called professional plumber. Remember that one Greg? the top of the retainer clip for the cartridge was oriented left, so hot in was coming through the shower out quadrant. Now, considering how this picture was posted................... Worth a check. Maybe the same "plumber?" His Brother? His Cousin?
Old 03-23-2013, 10:21 AM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 2,128
If the rough-in valve is anything like mine....the shower and tub pipes are one and the same. The only difference is that the tub spout closes which forces water up the pipe to the shower head.
So, in terms of operation...the water head will be slightly higher when going out the shower head due to the pipe going up and the restriction of the head.
So....if you have hot water going out the head, but not the tub spout....then, yes, it points to the cartridge....
Side note....I have my water heater turned down so that on full hot, it can not scold the kids. When I was taking a shower, the water temp was just warm enough for me to enjoy it....and that was on full hot. Recently I had the valve apart for a different reason...and then I noticed this ring on it...with stops.....hmmmmmm....the ring was set so that I could not get full hot water....rotated it so I got full hot.....Oh Lord, hallelujah....Praise the Lord....we have HOT water.....yea baby....
Knowledge is power.....and gets me hot water.
Old 03-23-2013, 10:47 AM   #10
Roofmaster
Your wife is supposed to scold the kids not your hot water
Old 03-23-2013, 11:00 AM   #11
JOATMON
ddawg16's Avatar
Naw...we just beat them with a wet noodle.....
Tags
help me please , hot water , oil burner , plumber , water pipe
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
