Hot Water Heating System Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-24-2012, 11:18 AM   #1
Hot water heating system plumbing
I need to move one of those under the counter heaters in my kitchen. It is attached to my forced hot water heating system. What should i do to drain the system and make sure that it doesn't fill itself while I am moving the heater? Kill power to the heater and turn off new water feed to heater. Is there an easy way to drain the hot water system? Once I turn it back on will it purge the air or do I need to do something.
blue33 is offline   Reply With Quote
Old 10-24-2012, 07:26 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 606
Ayuh,.... Whatcha got for a boiler, 'n piping system,....
Better yet, some Pictures....
There's a Million different ways yer system could be plumbed,...
Chances are, there's a spigot on the boiler/ heater, 'n you need to bleed the air out, after ya reseal the system...
Open Hydronic Heating System... how / need to bleed? MtnMan7 HVAC 1 11-19-2010 04:51 PM
Expansion tank - hot water heating system dianerob Plumbing 3 09-24-2010 06:39 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Air Scoop direction on a hot water heating system mmcr179 HVAC 2 03-17-2010 07:20 AM
uneven heating from hot water system JLAP Plumbing 9 12-21-2009 01:14 PM
