Hot Water Heater Reset Button Is Tripping - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2013, 11:23 PM   #16
Missouri Bound's Avatar
Originally Posted by Javiles View Post
Also make sure the thermostats are flush up against the tank if its separated just a bit you it wont pick up tank water temp.
...and this is VERY important.
Do you want it your way or the right way?
Old 02-20-2013, 11:52 PM   #17
Rewards Points: 47
The thermostats are flush against the tank and they are set to the same temp. The wiring is the same as the diagram sent to me and the tank is now working for 36 hours. The temp is set to 120. I had it on 135 , is that too hot? thanx
jeffs55 is offline   Reply With Quote
Old 02-21-2013, 06:01 AM   #18
Master Plumber
Javiles's Avatar
Rewards Points: 996
135 is fine mine is set at 150
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
jeffs55 (02-22-2013)
Old 02-26-2013, 12:11 AM   #19
Rewards Points: 47
A week of hot water thanks to the team here, thank you so much!
Old 02-26-2013, 08:02 PM   #20
Household Handyman
Rewards Points: 1,408
How old is this unit? The reason I ask is that I have ran across this problem with some older units and found that there was slight rust at the point of contact between the thermostat and the tank itself. Just a light sanding to remove the rust coating so the thermostat could make better contact solved the problem. Hope this helps.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Electric Water Heater Reset Switch C_J_GO Plumbing 11 01-20-2013 09:11 AM
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 02:54 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
