Old 11-02-2009, 09:35 AM   #1
Thumbs up Hot water heater relocation
I am moving my hot water heater from the front of the house to the rear. I want to use the old hot water feed at the front and add an additional hot water feed at the back. The middle of the house has two bathrooms that would be getting Hot water from both directions (A LOOP) Is this OK? Gary
gjp31254 is offline   Reply With Quote
Old 11-02-2009, 12:06 PM   #2
union journeymem plumber
130 plumber's Avatar
My main concern is what plans do you have for the flue pipe????how are you going to vent it out of the house????????????
130 plumber is offline   Reply With Quote
Old 11-02-2009, 03:30 PM   #3
My plumbing is in a straight line; hot water tank, kitchen, bath room, bath room, bath room, and then the laundry room. I simply need to move the tank to the other end of the line, "the laundry room" Because of the contruction of my house I can not run the hot water feed to the middle where it should be, I can run it to either end or both. I would like to run it to both ends so my kitchen and the laundry at the other end have equal performance (pressure and lag time) I don't need help with any other aspects of the job except "would a loop have any effect that I haven't consider like an air hammer effect"
Old 11-03-2009, 03:03 PM   #4
A loop would be fine... and it would accomplish what you want. I just don't see any real advantage. Actually a manifold using pex for home runs would be better and more efficient.
RegeSullivan is online now   Reply With Quote
Old 11-03-2009, 03:25 PM   #5
I have a manifold system in my summer house and loved it. The house we are taking about now is my winter house in south florida. It is a stilt house, the under side of the house is finished in stucco except for under the laundry room which was a deck at one point. Thanks
Tags
gjp31254@aol.com
More On This Topic
If your washing machine breaks, your power is out or you are going some place where you won't have access to laundry facilities, another way to get your clothes clean is to use a washboard. Doing your laundry with a washboard can take a lot of elbow... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will showing you how to dry the tank. For this step we are going to need a sponge and you may also might want to have a bucket with you. What we need to do now is sponge out as much water as... Read More »
Temperature for Baby Baths
Temperature for Baby Baths by Expert Village
Hi, I'm Liz Hood on behalf of Expert Village and I am going to be talking about how to give your baby a bath. One of the first things I want to talk about is about comfortable temperatures for your baby. Now one thing that you are going to have to do is... Read More »
Hi, my name is Leslie Moselle. I'm from Tampa, Florida and on behalf of Expert Village this is how to do laundry. The next step on doing your laundry is one of the most important steps of all and this is sometimes one of the steps that people actually... Read More »
A foot bath is commonly used to ease stress and fatigue while stimulating circulation in the feet. Many people find that adding ginger to the bath makes it even more relaxing and rejuvenating. Read More »
Low hot water pressure crebive Plumbing 24 11-07-2009 09:55 PM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 12:36 PM
Water Heater Problems martyshel Electrical 4 01-24-2009 02:07 AM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 01:30 PM
Water Heater tsmith Plumbing 10 12-01-2008 08:24 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
