Old 02-28-2012, 09:39 AM   #1
coz
hot water heater relief valve
I understand what the valve is for and how to replace it but what is the root problem? What causes the pressure or temp to be too high?
coz is offline   Reply With Quote
Old 02-28-2012, 10:42 AM   #2
Super Moderator
Some times they just go bad---but usually it is one of these:
Heater is full of lime--covering and insulating the temperature control rod on the back side of the gas valve.
To much water pressure---no expansion tank in system---
oh'mike is online now   Reply With Quote
Old 02-28-2012, 10:53 AM   #3
Also failed thermostat causing an over heated condition can do it.
The water out of the taps should be 120 deg. any higher and there's a danger of burns. A simple check with a thermometer will tell you.
Old 02-28-2012, 11:38 AM   #4
how old is this water heater.
Hardway is offline   Reply With Quote
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
Water heater keeps leaking out of TPR valve knac1234 Plumbing 10 08-14-2009 09:08 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 08:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
