Hot Water Heater Rattling Noises? (video) - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-22-2015, 03:55 PM   #1
Rewards Points: 18
Hot water heater rattling noises? (video)
Hello,
My hot water makes rattling noises when in use. I've attached a video, hopefully someone can identify the noise. Feeling the pipes, it seems to be coming from the outlet side.
jamesm113 is offline   Reply With Quote
Old 12-22-2015, 04:04 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,032
Try draining sediment from bottom of tank.
Coastal South Carolina
Old 12-22-2015, 04:41 PM   #3
Rewards Points: 18
No luck. And now the drain valve is leaking
Old 12-22-2015, 06:13 PM   #4
Rewards Points: 18
Ok the leak has subsided to a very slow drip. I suspect it might resolve itself.
However, it's still making a bunch of noise... What causes that noise... sediment?
Old 12-22-2015, 07:06 PM   #5
Rewards Points: 142
Watched your video several times. Hard to say. It's possible there could be a piece of sediment stuck in the outgoing line at the nipple causing the rattle. Sometimes there are rubber heat traps on those nipples that can trap sediment and cause that kind of noise.
What's the incoming water pressure and is there an expansion tank on the incoming cold water line? How old is wh?. Thanks.
When you feel the line does it definitely feel and sound like it's coming from the wh and not the exhaust duct work area?
jmon is offline   Reply With Quote
Old 12-22-2015, 07:24 PM   #6
Rewards Points: 18
No expansion tank, water heater was installed in 2000
Not sure on the incoming water pressure.
It definitely sounds like it's coming from the outgoing line. I put my ear up and could hear it clearly. It's not coming from the exhaust duct.
Old 12-22-2015, 07:32 PM   #7
Rewards Points: 142
Thank you for that info.
So almost 16 years old. Has it ever been annually serviced? like flushing, cleaning of burners, anode rod replaced, etc.?
Does that rattling vibration seem like it's coming from the outgoing nipple area? Thanks.
Old 12-22-2015, 07:57 PM   #8
Rewards Points: 142
Can't tell in video but do those nipples have a union for easy removal?
I'm thinking you have a ball or rubber type heat trap with sediment build-up that could possibly be causing the noise. Just a guess.
Unfortunately, the only way to know for sure is to remove the nipple. With a water heater that's over 15 years old, flushing sediment, old valves, removing nipples, etc., could be opening a can of worms.
As you found out when you opened and closed the wh drain valve, sediment got stuck and valve didn't close all the way causing it to drip now.
Please wait for the plumbers to respond, they will have more suggestions/advice. Thanks.
Old 12-23-2015, 11:29 AM   #9
Rewards Points: 275
I believe it is the metal fin that drops down the center of the tank to help the exhaust gas escape from the burner. I did a service call on a Rheem years ago and that part came dis lodged and rattled like that. Its under the flue cap.
Just a shot in the dark though, good luck
ct18 is offline   Reply With Quote
Old 12-23-2015, 12:41 PM   #10
Rewards Points: 370
Historically yes, sediment causes that noise. Your heater is about 18 or 20 in dog years so possibly after santa is nice to everyone you can save for a new heater.
SeniorSitizen is offline   Reply With Quote
Old 12-23-2015, 05:34 PM   #11
Rewards Points: 1,678
Your heater is due for replacement...
The Following User Says Thank You to Ghostmaker For This Useful Post:
jimn01 (12-24-2015)
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 09:48 PM
Water heater problems- thought I fixed the problem- what do I do next? brandall Plumbing 23 04-19-2013 06:44 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 12:35 PM
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-28-2010 12:00 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
