Hot Water Heater Rattling - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-04-2011, 10:48 AM   #1
hot water heater rattling
My 60 gal. hot water heater is 10 years old (Home Depot) and over the last year or so the rattling every time the hot water is turned on is finally getting to me. The more you open the faucet, the louder it gets. Is this a do it yourself issue or do I need to contact a professional? I am fairly handy and put in the master bath and bedroom in the attic myself.
Any suggestions?
Jamesbobby is offline   Reply With Quote
Old 12-04-2011, 10:58 AM   #2
DIY staff
Rewards Points: 7,174
Is this 'rattling'' happening each time hot water is used,any where in the house---
Or does this happen when the unit is 'cooking' the water?
I'll leave this to a plumber--after you add that important bit of info---
Old 12-04-2011, 11:03 AM   #3
Rewards Points: 1,542
Is the rattling from inside the heater or from a shutoff valve on top or alongside?
Have you drained sediment from the tank recently?
Draining about three gallons of water should accomplish this. If the water doesn't clear up by then then shut off the water heater burner (or power if electric) before draining any more, and run water from a hot faucet upstairs before turning the heating back on.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
