Hot Water Heater Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-30-2013, 06:48 PM   #1
hot water heater question
Quick question. Some guy at the local hardware store told me that hot water heaters require double wall b vent I told him not true as mine and others I have seen are single wall galvanized. Any opinions?
markharmon is offline   Reply With Quote
Old 05-30-2013, 07:24 PM   #2
Rewards Points: 1,766
It depends on the installation of the tank. If you are tying into an existing chimney no. If you are adding an entire chimney for the tank the part that enters the framing of the house will need to be double wall. This is for fire reasons.
Old 05-30-2013, 10:46 PM   #3
Its an existing chimney. When you have a direct vent pipe for a gas fireplace the square piece of flashing that is against the wall with the pipe running through the middle of it. Is that for fire purposes as well? To keep away from combustibles, i.e. the wall.
Old 05-31-2013, 05:13 PM   #4
Basically the flue gets hot and drys out the wood. Eventually it will cause combustion.
That usually pisses of your insurance company....
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 11:22 PM
Tankless water heater question Bennylava Plumbing 3 03-22-2013 06:40 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
