Hot Water Heater With Popping Sound - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-19-2007, 02:05 AM   #1
Rewards Points: 1,088
Hot Water Heater with popping sound
AO Smith hot water heater at about 9 years old. Heard that the popping sound could be sediment in the hot water heater. Will draining the tank get rid of the problem? Is its useful life about done?
handy man88 is offline   Reply With Quote
Old 10-19-2007, 10:45 AM   #2
47_47's Avatar
Rewards Points: 82
Is this a gas or electric water heater? Are you running out of hot water? Draining a tank is always a good idea to remove the sediments.
47_47 is online now   Reply With Quote
Old 10-19-2007, 11:39 AM   #3
This is a gas water heater. Hot water is not an issue. Just a popping sound coming from the tank.
Old 10-19-2007, 12:06 PM   #4
47_47's Avatar
Rewards Points: 82
I was leaning towards a bad dip tube. This is a tube inside the tank which directs the incoming cold water toward the bottom of the tank, but you have plenty of hot water. Other than that, I really do not have any practical solutions.
Old 10-19-2007, 01:37 PM   #5
RippySkippy's Avatar
The popping noise in the water heater is from the build up of sediment in the bottom of the tank. When the burner fires, the water between the tank and sediment will reach nearly boiling, and it's the lifting action of the water popping through the sediment that you hear. Check out this bulletin from A.O. Smith
Will flushing the tank take care of it? probably not...most likely the sediment will be nearly solid almost rock like and will not drain out. As the bulletin suggests, it you needs to be dissolved with an acid. It wouldn't hurt, but I doubt it will fix it either. You will however experience tank failure it could be in 2 years could be 10, but it will go bad. I would get in the habit of visually checking the tank frequently and/or get a flood monitor if you basement is finished.
With the water heater being 9 years old...and you don't want the hassle of worrying about flooding...replacement would be a viable option as well.
RippySkippy is offline   Reply With Quote
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-13-2007 11:16 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Leaky Water Sound 24/7, need your advice. clue89 Plumbing 1 03-02-2007 07:36 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
