Hot Water Heater Pan Sizing - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-01-2012, 09:45 AM   #1
Rewards Points: 1,088
Hot water heater pan sizing
What's the proper sizing for a hot water heater pan?
I have a 74 gal AO Smith gas HWH that I plan to get installed, and it has a diameter of 26.5" although the legs sit inside of this diameter. I figure maybe 1" clearance around the circumference, so min of 28"?
Aluminum of course, due to the gas.
handy man88 is offline   Reply With Quote
Old 01-01-2012, 10:13 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Big enough for the heater to fit in the pan. You can put it in a 26.5" pan if you wanted to. Doesn't make much sense, but it's not illegal and there are no code requirements for the size, other than the drain should be minimum 3/4"
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
plummen (01-01-2012)
Old 01-01-2012, 04:36 PM   #3
I was asking primarily due to the lack of availability of larger size pans at the big box stores.
Plus, a larger one allows access to the fitting if the need arises to tighten it.
I was able to find a 28" diameter one one at Lowe's today, so that should suffice. Thanks.
Old 01-01-2012, 06:17 PM   #4
Rewards Points: 582
yes it will if the tank fit inside...
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-27-2010 11:00 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
