Hot Water Heater Mineral Buildup - Removing Encrusted Element - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-03-2007, 05:54 AM   #1
In the process of doing some hot water heater maintenance, I discovered the lower heating element encrusted in mineral buildup. There is so much buildup that I cannot pull the element completely out of the tank to properly clean it. I was thinking about dumping some vinegar into the tank and let that dissolve the buildup enough to get the element completely out. Is there any reason I shouldn't try this technique or does anyone have another suggestion? Where is the best place to get a replacement o-ring for the element? I believe the element is still good after testing its resistance with my multimeter.
Also, unrelated to the water heater question, is it OK to connect PVC to ABS?
Thanks!
Steve VA is offline   Reply With Quote
Old 04-03-2007, 08:54 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Just replace the element, there not the expensive, and yes use a fernco rubber coupling to make the transition between the two types of pipe.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
