Hot Water Heater Leaking From Top - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-12-2010, 06:32 PM   #1
We have an older hot water heater that is leaking from the top of the tank onto the floor. Not a lot but enough. Specifically, it is leaking from the cold water intake brass tube, apparently where it hooks up to the tank. Water is apparently leaking into the small little well, fills up, gets warmed by the tank and then spills out on the floor.
I am hoping that it is the seal between the copper pipe to the tank. There is a lot of white corrosion around the seal so it doesn't look like 'die-electric' seal was used there. Can this be replaced easily?
I also noticed that there is a turn valve at the other end of the copper pipe, just before the pipe goes into the wall (and outside the house?). I tried turning it---not hard---but it wouldn't budge. Is this a seperate water supply turn off to the tank?
Since we're dealing with natural gas and hot pipes, I just want to get more information before I do anything. And I pray we don't have to replace the tank because we can't afford it. Any thoughts, suggestions, or ideas?
jim.flack is offline   Reply With Quote
Old 01-12-2010, 10:21 PM   #2
Do something
D'Brie's Avatar
Some information
Originally Posted by jim.flack View Post
We have an older hot water heater that is leaking from the top of the tank onto the floor. Not a lot but enough. Specifically, it is leaking from the cold water intake brass tube, apparently where it hooks up to the tank. Water is apparently leaking into the small little well, fills up, gets warmed by the tank and then spills out on the floor. How old is old? If more than ten years old you'll be wasting money on repairing rather than replacing.
I am hoping that it is the seal between the copper pipe to the tank. There is a lot of white corrosion around the seal so it doesn't look like 'die-electric' seal was used there. Can this be replaced easily? Your tank is limed out, probably a good time to replace it.
I also noticed that there is a turn valve at the other end of the copper pipe, just before the pipe goes into the wall (and outside the house?). I tried turning it---not hard---but it wouldn't budge. Is this a seperate water supply turn off to the tank? This is your water heater cold supply line, when you close this valve, no more water will enter your tank.
Where are you in WA?
D'Brie is offline   Reply With Quote
Old 01-13-2010, 05:36 PM   #3
Rewards Points: 1,418
If the leak is in the piping just above the tank, then it is not a big deal to replace just that piping, perhaps one nipple that screwed into the tank and a copper fitting or two just above.
You may have to chisel out the remains of the nipple in the top of the tank, be careful not to mar the threads so much that the new nipple doesn't make a leakproof joint.
Old 01-13-2010, 05:56 PM   #4
Civil Engineer
Rewards Points: 4,514
I had a similar problem when a galvanized steel nipple was installed into a hot water tank without a dielectric fitting. The white material on the nipple was due to corrosion of the galvanized steel. The connection was ruined, I had to replace the heater, when I did you can be sure I put in a dielectric union. No problems in 6 years.
Tags
cold , heater , hot , leak , water
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
Water heater keeps leaking out of TPR valve knac1234 Plumbing 10 08-14-2009 09:08 PM
water heater leaking from cap 2much2do Plumbing 3 03-17-2009 06:43 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 08:18 PM
Water heater is leaking from the top lmlboone Plumbing 12 10-01-2008 04:18 PM
