Hot Water Heater Leaking From Top - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-20-2011, 11:58 AM   #1
Hot water heater leaking from top
My hot water heater started leaking yesterday from the top of unit but not from either of the hoses. I was just wondering if I could do anything to get me through a few days before I get a new one. Thanks
urjellybean03 is offline   Reply With Quote
Old 06-21-2011, 12:24 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
What is leaking? The T&P valve? The tank? A fitting?
If it appears to be the tank, you should replace it asap. It could burst and you would have a major flood on your hands if you weren't around to turn off the power or gas and water to it immediately.
Mike
Mike Swearingen is offline   Reply With Quote
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
