Hot Water Heater Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-12-2014, 07:37 AM   #1
Rewards Points: 283
Woke up this morning and noticed my hot water heater is leaking. Nothing terrible, just a very slow drip.
Unit is over 10 years old and needs to be replaced.
Two questions:
1. how can i stop the drip until it's replaced?
2. how much should i expect to pay to have a new one installed? parts + labor. i live in an area where plumbers charge 150-200/hr
marcus118 is offline   Reply With Quote
Old 04-12-2014, 07:41 AM   #2
Rewards Points: 20
Where is it leaking from? Gas or electric?
Dan
djlandkpl is online now   Reply With Quote
Old 04-12-2014, 07:52 AM   #3
Rewards Points: 283
its a gas heater. cant see where it's leaking. somewhere on the bottom of the tank.
Old 04-12-2014, 08:10 AM   #4
Rewards Points: 20
If you can't find the leak, time to get on the phone and get some estimates. Too many variables to give you a price on the forum.
Dan
Old 04-12-2014, 08:16 AM   #5
Rewards Points: 283
ok so turned off water supply, turned gas valve to off and now draining the tank with a garden hose.
sound about right?
Old 04-12-2014, 08:18 AM   #6
Rewards Points: 20
Yes. That'll do it.
Dan
Old 04-12-2014, 11:51 AM   #7
Rewards Points: 1,864
Perhaps you should go to home depot it get one yourself. Buy a tank that has the exact same type of venting. And a water heater tank connection kit. Before you start take a picture so we can see if it is a difficult install. Also we need to know your state for code compliance.
While draining make sure you open the hot water on a faucet in your house.
Old 04-12-2014, 12:36 PM   #8
DIY staff
Rewards Points: 7,174
Just a small suggestion---
Buy your new heater from a plumbing supply house----they will stock repair parts for the models that they sell---heaters from the big stores? If you need a part--you must order from the manufacturer and wait for the mail to deliver it.
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Tankless Water Heater a7ecorsair Plumbing 56 05-04-2012 09:17 AM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 02:35 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
