-   -   Hot Water Heater Drain Valve (http://www.diychatroom.com/f7/hot-water-heater-drain-valve-82500/)
Mitch125 09-27-2010 05:43 PM
I have a well with a submersible pump. When I shut the supply line off from the pump, aand open the drain valve on the water heater, water does not flow out. I wanted to change or remove the Anod Rod, but want to make sure there is no pressure inside the tank. I was confused when no water came from the drain valve, unless I turn the well valve back on.
kenmac 09-27-2010 07:14 PM
Open an outside spigot. The water should come out. When you turn the pump on you are forcing the water out
AllanJ 09-28-2010 10:14 AM
Turn off the water heater heating (turn the small knob from Run to Pilot on gas models).
After turning off the main water supply, open all hot water faucets upstairs and then drain at least three gallons from the water heater drain valve to get all the water in the pipes above you out. Otherwise it will get all over you when you unscrew the anode rod.
Have water running from an upstairs hot faucet before turning the water heater back on, to be sure the tank is full first.
secutanudu 09-28-2010 10:56 AM
If you have no faucets open....it's sort of like holding a drinking straw full of water with your thumb over the top...you need to let air in to push the water out.
jounderw 09-28-2010 12:07 PM
opening an outside spigot as someone mentioned earlier should do the trick. We had a similar problem and it turned out to be a pressure issue and it seems like this is too. Great analogy with the "finger over the straw"- thats exactly what I think is going on here.
