Hot Water Heater Continuously Resets - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-29-2013, 01:54 PM   #1
Rewards Points: 51
Hi,
I noticed the other day that all of the sudden I had no hot water. I took the cover off of the unit and pressed the red reset button and then there was hot water again. Unfortunately, I noticed that the water was hotter than it should have been and by the next morning it had tripped again. So, obviously something is wrong. The unit is a 40 gallon electric State Select and if I'm interpreting the serial number correctly it was manufactured in May 2006 which makes it about 7 years old. I'm a bit strapped for cash at the moment so I'd like to avoid replacing the unit.
I know almost nothing about water heaters but based on the googling that I just did it looks like the problem can be one of two things. Either the thermostat is stuck or the element is grounded. I have a number of questions, some of which I'm sure are a bit silly.
(1) Do all hot water heaters have two elements / two thermostats? I only have one place on mine to set the temperature. Does that mean that there is only one thermostat? There is a second cover higher up but behind it there is only a metal circle looking thing. (see photo) Can someone tell me what that is?
(2) How can I determine whether the problem is a bad thermostat or a grounded element? I do have a multimeter, though not a lot of experience using it Generally though I am smart enough to at least not kill myself.
(3) How likely is it to be one or the other. Is it like 50/50 or 90/10? I ask because it looks like replacing the element may be more than I can handle, but the thermostat doesn't look too bad.
(4) Where can I find the right thermostat? Are they standard or do I have to find the exact thermostat for my model? I live in a small town. There is a walmart but no real hardware stores. Are they likely to carry it?
Thanks in advance!
rs1971 is offline   Reply With Quote
Old 05-29-2013, 04:28 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 994
water heaters come with single or double elements, 99.9 percent of the times when the red button pops its the thermostat. temper plate inside go bad and they wont shut down at preset temp they over heat then the emergency reset pops, you'll need to make sure its a single element, most are interchangeable brand to brand, buy the package element and thermostat, if you cant find them locally order on line, make sure of the voltage and wattage before you order, element has nothing to do with the reset popping but if its 6 to 7 years old go ahead and replace the element while your at it.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
rs1971 (05-29-2013)
Old 05-29-2013, 05:01 PM   #3
Rewards Points: 51
Hi,
Thanks for that. I'm still not sure how many elements it has. Is there always the same number of thermostats as elements? I tried finding the manual online but wasn't able to, probably because it is so old. The model number is ES640SORT and it's manufactured by State. Anyway, I'm including photos here of what's behind the upper and lower panel so hopefully someone can give me a clue.
UPPER PANEL
LOWER PANEL
Thanks again.
Old 05-29-2013, 05:09 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 994
Each element would have its own thermostat, Thats a single
Old 05-29-2013, 05:12 PM   #5
Rewards Points: 51
Okay, that's what I thought. But what's the thing metal thing under the top cover?
Thanks.
Old 05-29-2013, 05:44 PM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 994
That would be the port for the top element
Old 05-29-2013, 05:57 PM   #7
Rewards Points: 51
Ah, ok. So this geometry could support one element or two. That's interesting.
Thanks again.
Old 05-29-2013, 06:45 PM   #8
Rewards Points: 1,858
http://www.statewaterheaters.com/lit...185225-000.pdf
Old 05-29-2013, 07:12 PM   #9
I learned a long time ago to replace both the stat and element.
koplumber is offline   Reply With Quote
Old 05-31-2013, 12:28 AM   #10
Rewards Points: 51
Okay, thanks everyone for all the help. I have one last question. I just finished replacing the thermostat / element and I'm waiting for the water to get hot. There was one small snafu. The geometry in the replacement thermostat is slightly different than that on the original and as a result the plastic cover doesn't fit anymore. I guess I could just leave it off, but I like to get things done right. Is there somewhere I can find a plastic cover that will fit my thermostat? I poked around online and I couldn't find anyplace that sells them at all.
Thanks again.
Old 05-31-2013, 06:56 AM   #11
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,044
Just cut a hole in your existing on and make it fit.
You can tape over the old hole.
Old 05-31-2013, 09:05 AM   #12
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Some thermostats come with new covers. The ones we get don't. I just usually have to snap off one of the "legs" on the old cover and it fits fairly closely to what it used to fit on the old one. It doesn't sit tightly, but it stays there by itself.
Journeyman Plumber
Old 05-31-2013, 04:01 PM   #13
By the way make sure you do not turn the power back on until you have a full tank with water running out a faucet... Elements will fry in open air.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Water heater problems- thought I fixed the problem- what do I do next? brandall Plumbing 23 04-19-2013 05:44 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
