Hot Water Heater Blanket - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-08-2012, 09:11 AM   #1
Rewards Points: 140
hot water heater blanket
been a while since this was made a topic.
my hwh is about 8 years old, and looks to be in very good condition. 50gl i think.
it is in the basement, 60deg right now. but it may get colder as winter moves in. we moved in just after last winter, so i have no experience with this basement in winter.last night i check it with my temp gun. it was about 73 towards the top, and got hotter as i went down.
Fix'n it is offline   Reply With Quote
Old 12-08-2012, 09:17 AM   #2
bbo
gas or electric? gas you need to be careful not to insulate near the pilot light or flue.
make/model? Manual should tell you if recommended or not.
do you have access to the HW pipes coming out? insulating them will help, again being aware of recommendations on your model of WH.
bbo is offline   Reply With Quote
Old 12-08-2012, 09:22 AM   #3
Rewards Points: 140
richmond, gas, 50gl, 6y/o. electric pilot. yeah, all of the pipes are accessible .
Old 03-18-2013, 09:54 PM   #4
Rewards Points: 140
i put a $10 walmart fiberglass blanket on it several weeks ago.
it does make a difference. the water stays hotter, longer.
WELL worth the money and effort.
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 12:35 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-28-2010 12:00 AM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
