Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2010, 10:29 AM   #1
Question
Hot Water Heater
I need to disconnect and move my hot water heater so my drywallers can repair the walls in the utility room.
My questions are when I drain the water heater do I need to disconnect the main water line outsice or just the valve bringing water into my water heater?
Does it matter when I disconnect my electrical from the water heater?
csrg83 is offline   Reply With Quote
Old 01-28-2010, 10:33 AM   #2
E-lec-tri-city
Rewards Points: 150
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
Isn't "hot water heater" redundant?
Anyways, when I moved mine I only turned off the spigot that supplied water to the heater and not the house water. That seemed to work fine, once I had the faucet tight enough anyways.
brons2 is offline   Reply With Quote
Old 01-28-2010, 10:35 AM   #3
Rewards Points: 5,336
There should be shutoff valve dedicated to the heater. You only need to shut those off.
I'd shut off the electric before I started with the piping. Water will come out of the p[ipes and fall on the water heater.
Ron
Old 01-28-2010, 11:02 AM   #4
Rewards Points: 1,492
Turn off the power before turning off the water.
Open some hot faucets upstairs when draining the tank so all the water in the pipes comes down quickly and also the tank drains faster. Then turn those faucets off, see below. The tank should be empty before it is moved.
Turning off just the shutoff in the cold pipe above the water heater is good enough but if someone upstairs turns on both hot and cold faucets, the water will go down the hot pipe backwards and get all over your drywall repairmen.
Do not turn the water heater power back on until all the pipes are reconnected and you have water running out of a hot faucet upstairs.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 10:36 AM
Water Heater Problems martyshel Electrical 4 01-24-2009 12:07 AM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 11:30 AM
Water Heater tsmith Plumbing 10 12-01-2008 06:24 PM
