Hot Water Heater?????????????? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-05-2009, 12:44 PM   #1
hot water heater??????????????
I have an 80 gallon hot water heater that is dripping from the pressure relief valve.not much, not even a pint in a few days, I was told to shut the power off (its electric) shut off the feed drain some water from the tank and then try releasing the pressure.
well i shut off the water hooked up a hose to the drain and no water came out i then tried the pressure relief valve and got nothing. am i doing something wrong is it just junk and need to call a plumber? any advice would be appreciated.
malahide66 is offline   Reply With Quote
Old 07-05-2009, 01:36 PM   #2
The bottom of the tank is probably filled with solids from the minerals in the water. These solids will block the flow of water and plug the valve.
Usually when this happens, the water heater is very old, and the water is very hard. You can remove the drain valve to try to clear out the deposits, but before tackling such an operation, be prepared to replace the heater, as drain valve removal has been known to spin out the valve tapping due to corrosion. When this happens, it's new heater time.
The "relief valve" is actually a Temperature-Pressure relief valve. When the water is heated the expansion due to heating causes an increase in pressure in the vessel. When the pressure builds to the set point (Usually 125 psi) the relief valve relieves the pressure in the tank.
You need to establish an air cushion to correct this situation.
I found the best way is to install a "Bladder tank" at the cold water inlet. This simple device compensates for water expansion and contraction during the heat cycle.
The temp/pressure (TP Valve) is not designed to cycle too many times. After repeated cycling the seat will become damaged and the valve will leak all the time.
Houndawg is offline   Reply With Quote
Old 07-05-2009, 01:41 PM   #3
thanks we were thinking of just replacing it anyway.
Old 07-05-2009, 04:29 PM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
.......the seat will become damaged and the valve will leak all the time.
Congratulations to Houndawg for an excellent first post.
malahide66 I had a similar problem with the TPR on my Water Tank so I replaced it with a new $12 TPR . It will not make an old tank like new but it should fix the dripping. The TPR design is pretty much standardized
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-05-2009, 06:21 PM   #5
HVAC / Plumbing
You will need to test water pressure to know for sure. But you may require an expansion tank/ water pressure regulator on the main water line
kenmac is offline   Reply With Quote
Old 07-05-2009, 07:34 PM   #6
Tool Geek
PaliBob's Avatar
DIY'ers That are tool geeks have one of these:
http://www.amazon.com/Rain-Bird-Wate.../dp/B00004RACK
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-05-2009, 09:21 PM   #7
HVAC / Plumbing
I agree,,, Being in the plumbing bus. I've been using them for years
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 11:36 AM
Water Heater Problems martyshel Electrical 4 01-24-2009 01:07 AM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
Water Heater tsmith Plumbing 10 12-01-2008 07:24 PM
