Old 10-30-2007, 11:26 PM   #16
Hot Water Heater
have and new electric hot water heater but it will not get hot just warm
i thought it was the heater but took it back and got another one and stell have the same problem help help help.
betty is offline   Reply With Quote
Old 10-30-2007, 11:38 PM   #17
Hot Water Heater
need help i just bought a new hot electric hot water heater and it will not get passed the warm stage . thought the frist one was bad but this is doing the same thing can someone help me quick with a reason why .
thank you
Old 10-31-2007, 02:37 AM   #18
Long-Time DIYer
Mike Swearingen's Avatar
Hot Water Heater
Betty,
Who is installing these water heaters? DIY or a pro.
If someone turns the power ON before the heater is filled with water, it will fry one or both of the elements, which is my guess that the problem may be.
Turn OFF the power. Disconnect both wires to each element, and test it with an ohm meter. No continuity, replace the element.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 10-31-2007, 11:03 AM   #19
Unhappy
Hot Water Heater
Originally Posted by Mike Swearingen View Post
Betty,
Good luck!
Mike
he did let it fill with water . now he is checking out the voltage
Old 10-31-2007, 11:06 AM   #20
Hot Water Heater
help help help on my water heater problem desperate
Old 10-31-2007, 11:08 AM   #21
Hot Water Heater
Is "he" a plumber? Or a DIY'er?
I'm assuming this is an electric heater?
I don't suppose there's any chance this is a 220V heater hooked up to a 110V circuit, is there?
NateHanson is offline   Reply With Quote
Old 10-31-2007, 11:11 AM   #22
Hot Water Heater
he is checking now to see if there is enough voltage comeing in
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Chimney Liner for Water Heater mruggeri001 HVAC 6 01-10-2007 07:08 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
