Old 12-30-2012, 06:33 PM   #1
Hot Water Heater
I currently have 2 hat water heaters located in 2 separate places in the house. 1 electric and the other is propane ( that use to be solar). The propane tank has been removed because it is located outside right next to a bedroom window, a very dumb location. Now we do not have hot water to the 2 back bathrooms and have considered just using the one and just getting a larger unit. How difficult will it be to tie in the plumbing?
total fixer is offline   Reply With Quote
Old 12-30-2012, 06:46 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Hot Water Heater
Hard is only if you are on a slab and did not have crawlspace or a basement.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
The Following User Says Thank You to gregzoll For This Useful Post:
total fixer (12-30-2012)
Old 12-30-2012, 06:58 PM   #3
Hot Water Heater
Lucky us, we are on slab.
Old 12-30-2012, 07:34 PM   #4
gregzoll's Avatar
Hot Water Heater
You could always tie in within a inner wall with PEX. That would mean cutting into drywall to pull the tubing between, to act as a jumper.
Old 12-30-2012, 07:38 PM   #5
Plumber & Gasfitter
Hot Water Heater
Depending on your climate, you may also be able to go through the attic with some insulation and potentially some heat trace.
Even with heat trace, if you live in a climate that is susceptible to freezing, you're better off keeping all water connections within the heated part of the house.
joeplumber85 is online now   Reply With Quote
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
