Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2012, 03:29 PM   #1
hot water heater
drain cover is melting on hot water heater
kodiak16 is offline   Reply With Quote
Old 01-28-2012, 04:27 PM   #2
Rewards Points: 13,994
A picture would be nice, or at least let us know what a drain cover is.
There should be a drain that looks like an outside faucet valve but I've never seen one with a cover on it.
Is it a gas or electric heater?
Old 01-28-2012, 07:27 PM   #3
Rewards Points: 582
sounds like your getting flame roll out from clogged flue..and its melting the plastic grip for drain???
The Following User Says Thank You to ben's plumbing For This Useful Post:
Plumber101 (01-28-2012)
Old 01-28-2012, 08:21 PM   #4
Rewards Points: 1,088
Yes, someone else refers to it as a "hot" water heater also!
In actuality, it's correct. It's heating the cold water and making it hot, but it's also keeping the hot water in the tank hot.
So, it is a hot water heater!
handy man88 is offline   Reply With Quote
Old 01-29-2012, 07:12 AM   #5
Rewards Points: 1,216
"Hot Water Heater---Water Heater -- don't matter we should all know what it refers to". DIY not Journeyman.
COLDIRON is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
