Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-09-2012, 05:07 PM   #1
jaj
Hot water heater
What would cause a hot water heater to drain out an outside airvent?
jaj is offline   Reply With Quote
Old 01-09-2012, 05:25 PM   #2
MarginallyQualified
Rewards Points: 2,464
As there is no such thing as an "outside airvent" associated with water heater... we're left to assume that you have something else going on.
My crystal ball says that the relief valve pipe exits outside...
and for one reason or another it blew off.
Look for where/how that pipe connects with the water heater...
tell us what you find.
The Following User Says Thank You to TarheelTerp For This Useful Post:
jaj (01-10-2012)
Old 01-10-2012, 01:14 PM   #3
jaj
Hor Water Heater
Thank you! We think your crystal ball is right on. My husband is replacing the pressure relief value. We are still concerned about what caused it to blow. It is our secondary heater that we keep it turned down to pilot light until I wash clothes. I had turned it up to high as I was going to do laundry prior to the hot water coming out the pressure value drain. Could it be a faulty thermostat?
Old 01-10-2012, 02:41 PM   #4
MarginallyQualified
Could be... frequent up and down adjustments isn't advisable.
How often do you do hot water (whites?) washes?
Water heaters are like mothers in law: the less you mess with them the better.
Find a reasonable compromise that suits most of your needs and then leave them (both) be.
Old 01-10-2012, 02:46 PM   #5
biggles's Avatar
might just want to go to PILOT position on the dial and not touch the temperature dial then when you need the wash hot water just put the valve knob to ON from pilot and the burner should start..those dials are just bi-metal and aren't designed to be turned up and down....the relief was doing its job in blowing off the HWH tank
The Following User Says Thank You to biggles For This Useful Post:
jaj (01-10-2012)
Old 01-10-2012, 03:38 PM   #6
Rewards Points: 1,442
Water expands when heated. If your system does not have an expansion tank and does have a check valve to prevent backing up into the water main, then each time a new tankful is heated, the pressure/temperature relief valve may trip.
AllanJ is online now   Reply With Quote
The Following User Says Thank You to AllanJ For This Useful Post:
jaj (01-10-2012)
Old 01-10-2012, 06:12 PM   #7
jaj
Thank you so much for sharing your knowledge and humor. We will implement your suggestions. I never cease to be amazed at what you can learn on the computer. Great helpful site.
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
