Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-28-2011, 04:38 PM   #1
hot water heater
corrosion at connection of hot/cold water lines, how to prevent?
Ol Timer is offline   Reply With Quote
Old 08-28-2011, 05:10 PM   #2
Experienced
Jackofall1's Avatar
I would suggest you stick with the original post or one post for the same topic, much easier to follow,
As suggested add dielectric unions on both the in and out from the heater to prevent galvanic reactions.
Mark
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
