Hot Water Heat Piping - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-06-2010, 08:46 AM   #1
JPM
Bill Traver
Rewards Points: 99
I have an older rental property that has one boiler, two circuits. One circuit is for the 3rd floor and is baseboard. The other is for the 1st and 2nd floors (one common thermo for them). It is radiator style heat. The second floor is much cooler. To balance the heat, I was thinking of (1) removing a radiator section from the 1st floor, (2) breaking the line and adding either a radiator or baseboard on the 2nd floor ---> if so, I am going from 2"(?) black to 1"copper ---> gotta be an issue with flow there? Could I WYE off the black and run two lines then bring them back together at some point?
I am just starting to think about this so I apologize for not being more specific, but any recommendations/comments will help me get focused.
Thank you!!
JPM is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Hot Water Heat Layout Question spook74 HVAC 25 01-12-2010 11:00 PM
Water Source Heat Pump installation JLMitchell HVAC 6 11-30-2009 04:23 AM
