Hot Water Going Instantly Cold - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-14-2012, 10:26 PM   #16
Special User
Rewards Points: 1,230
Yes they should, but if it's not too much trouble to leave your water turned off for a while, I'd pull the old cartridge to take to the store with you. Just to make sure you get the right replacement part.
If you're lucky, the old cartridge will come out without using a puller. I was not lucky on mine, so rather than buy a puller tool, I just called a plumber.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-15-2012, 07:04 AM   #17
Ruales Building Service
Originally Posted by brockmiera View Post
Whenever the shower is running and something as little as the kitchen faucet is turned on the shower water goes instantly cold. Any thoughts on why this might happen?
Is it electric?
If so the bottom heating clement is not working and only heating the top portion of the tank and that is why you run out quickly.
rualesbuilding is offline   Reply With Quote
Old 12-15-2012, 04:32 PM   #18
DIY staff
Rewards Points: 7,174
Yep---and the puller---free from Moen if you don't mind waiting for the mail-----Buy the real one--there are aftermarket cartridges available---I never used one,seems like a poor choice---
Old 12-15-2012, 04:39 PM   #19
Special User
Dang, wish I'd known that!
Tags
cold , plumbing , scalding , shower , water
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
No cold water!! Hot coming out in the cold faucet! HELP Marilynjp Plumbing 6 01-04-2010 06:40 PM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 01:29 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
