Old 10-18-2012, 03:24 PM   #1
"You can do anything"-Mom
brockmiera's Avatar
Hot water going instantly Cold
Whenever the shower is running and something as little as the kitchen faucet is turned on the shower water goes instantly cold. Any thoughts on why this might happen?
brockmiera is offline   Reply With Quote
Old 10-18-2012, 03:38 PM   #2
The faucet is turned on cold or hot in the other room?
pwgsx is offline   Reply With Quote
Old 10-18-2012, 03:44 PM   #3
New house to you?
What size are the main runs?
Single or double handle faucet?
About how old is it.
Old 10-18-2012, 03:58 PM   #4
brockmiera's Avatar
Either way the same thing happens.
Old 10-18-2012, 03:59 PM   #5
brockmiera's Avatar
Originally Posted by joecaption View Post
New house to you?
New house to me yes. Built 1961
If I had to guess Id say 1.5" is the main line coming in to the house. All other pipes look the same size. I can measure later today.
Single handle faucet in the shower.
Old 10-18-2012, 08:36 PM   #6
Super Moderator
The preasure balancing cartridge in the shower is faulty---change the shower cartridge--
Let us know the brand and we'll walk you through it---If the house is new---call the builder---simple,quick fix usually---
oh'mike is online now   Reply With Quote
Old 12-13-2012, 10:21 AM   #7
brockmiera's Avatar
sorry it took so long to get some of this information back to you guys. here is a picture of the unit I took this morning. I'm still not quite sure which brand it is. also what would I do to make this bad dripping stop
Old 12-13-2012, 12:36 PM   #8
brockmiera's Avatar
New house to you?
And my house main is 3/4" copper pipe. It is immediately sized down to 1/2" throughout the rest of the house.
Old 12-14-2012, 03:13 PM   #9
Special User
That small piping may be a contributor, but I agree with oh'mike, a new pressure balance cartridge is in order.
That looks like it might be a Moentrol, but I will let someone with more experience confirm or deny.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-14-2012, 08:22 PM   #10
mike is ontop of this one.....change out cartridge in shower 1st . its a moen...ben sr
Old 12-14-2012, 08:53 PM   #11
brockmiera's Avatar
Would you mind terribly explaining how?
Old 12-14-2012, 10:09 PM   #12
Special User
http://www.youtube.com/results?searc...place+moentrol
Old 12-14-2012, 10:52 PM   #13
brockmiera's Avatar
Originally Posted by tylernt View Post
Cool thanks ill check it out
Old 12-14-2012, 10:54 PM   #14
Super Moderator
Turn off the water at the main---
Remove the handle---and the big cover plate---you will see a horseshoe shaped clip that is in
front of the valve body--lift that out---attach a Moen cartridge puller to the stem--
-turn the handle on the puller----cartridge should pull right out---(sometimes you will need to crank the handle back and slip an open crescent wrench under the puller,as a spacer to complete the pull)
Roll up some sand paper and lightly sand the inside of the valve body---rinse out the grit--
Lubricate your new cartridge and install---replace clip---put cover and handle back on---
Old 12-14-2012, 11:18 PM   #15
brockmiera's Avatar
Right on! Thanks a bunch. Ill let you know how it goes. Can I get this catridge at big box?
Tags
cold, plumbing, scalding, shower, water
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 06:55 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
No cold water!! Hot coming out in the cold faucet! HELP Marilynjp Plumbing 6 01-04-2010 07:40 PM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 02:29 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
