Hot Water Goes Cold... - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2009, 02:12 PM   #1
Electrician
Hot water in shower goes cold after 5 minutes
After short periods of time in the shower, the hot water seems to change to ice cold. I really don't know anything about plumbing, so was wondering what everyone thinks about it? Are there any reasons that the water might be losing it's temperature? Sometimes it doesn't get cold as quickly, or it will be cold for 5-7 minutes then heat up again.
help anyone?
raggedbeefman is offline   Reply With Quote
Old 01-31-2009, 03:56 PM   #2
just a guess but sounds like you have a boiler without a separate hot water tank. Could just be the heating element cycling. Turn down the stat next time you shower so the boilers not heating both the hot water for your shower and the baseboard(?) hot water.
II Weeks is offline   Reply With Quote
Old 01-31-2009, 04:01 PM   #3
Electrician
ok, if it helps i can take a picture of my furnace/tank stuff to show on here. I will try that next time to see if that helps.
Old 01-31-2009, 04:25 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,638
Ayuh,...
You haven't stated Any of the facts needed....
How is your water Heated,..??
Electric,..??
Gas,..??
Stand alone Waterheater,..??
Coil off the house heating system,..??
Ya gotta atleast give Us a Few Hints,....??...
Old 01-31-2009, 06:40 PM   #5
Electrician
it runs off of our heating system, which uses oil and is a steam system.
Old 01-31-2009, 07:08 PM   #6
Rewards Points: 1,538
Things to try:
Turn off washing machine faucets before the hoses.
Make sure other bathtubs and showers are turned up using faucets and not the sprayer or shower head. This is to prevent cold water from crossing over and going the wrong way down the hot water pipes.
Does your plumbing system have an anti-scald mixer down near the furnace? This might malfunction causing a lot of cold water to enter the hot water pipes.
Old 01-31-2009, 07:11 PM   #7
Electrician
I'm not sure what an anti scald mixer is? What does it look like?
Old 02-01-2009, 06:17 AM   #8
the Musigician
DangerMouse's Avatar
it could also be a faulty scaldguard valve in the shower itself, if you have that.
it's kinda like the thermostat in your car. it gets too hot, it opens to let in more cold water.
if faulty, it could be doing what you describe.
i love ours, no toilet shock or pressure loss when a flush happens!
DM
Old 02-01-2009, 07:55 AM   #9
Electrician
how would I go about fixing that?
Old 02-01-2009, 08:43 AM   #10
the Musigician
first, you need to see if you have one, pull the knob from the shower and see if there is an adjust for temp.
if so, that may be the problem.
http://images.google.com/images?clie...-8&sa=N&tab=wi
look through these images and see if you see anything that looks familiar from your plumbing.
DM
Old 02-01-2009, 08:50 AM   #11
Electrician
ok will do, I have multiple showers that this happens too, could it be the same problem with them? or is there an anti-scald downstairs I can look at? If so, what does it look like?
Old 02-01-2009, 09:03 AM   #12
the Musigician
if it happens in more than one shower, then it's not a scaldguard in the shower problem. look through the images i posted the google link to and see if you see anything that you may have downstairs.
DM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 01:36 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
cold water runs hot phxhouser Plumbing 4 06-11-2008 09:03 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
