Hot Water Flow Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-23-2013, 08:16 PM   #1
Hot water flow problem
Getting poor flow in the 2 upstairs bathrooms. Have cleaned the faucet traps, put in new shower heads, purged one hot water line at the lavatory faucet. Have drained gas hot water heater twice. Didn't see any significant debris. Heater is 4 years old.
Still poor flow. My guess is that a valve in the supply line has a blockage or something inside the heater is blocking flow. Home is 90 years old and the copper lines appear to be the original but don't know for sure.
Any ideas would be appreciated.
BillW1950 is offline   Reply With Quote
Old 09-23-2013, 08:21 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
Welcome Bill!
Moved your thread to the plumbing board
Is the flow bad on hot and cold?
Old 09-23-2013, 09:39 PM   #3
Just hot water.
Old 09-23-2013, 09:39 PM   #4
E, thanks for the reply and moving the post.
Old 09-23-2013, 11:01 PM   #5
Rewards Points: 226
Could be a number of things going on here. Your guess is a possibility. Do you have any old galvanized pipes that may be causing the issue or do you have all copper? You mentioned your house is over 90 years old, may still have some old galvanized pipes somewhere that need to be replaced.
Quick thing to check, turn off supply line to the low pressure fixture, take off the supply line from faucet and hold in bucket, turn on supply valve, and see what kind of pressure you have. Go from there.
jmon is offline   Reply With Quote
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Hot water pressure problem (unusual situation) tanna Plumbing 2 09-03-2011 09:17 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 10:03 AM
