Old 11-24-2012, 01:05 PM   #1
Hot water flow problem
I have a gas hot water heater - Reliance with 40 gal tank. Was in the house when I bought it 4 years ago, so I'm not sure of its age. Recently the hot water will not flow for a minute or so, or comes out as just a trickle. Turn the faucet on and off a few times and it will flow again. Is there some kind of valve that would stick to prevent the flow? thx for the help
kmccoy is offline   Reply With Quote
Old 11-24-2012, 01:09 PM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,... Is this with just 1 faucet, or all the hot water faucets,..??
If only 1,... I'd start there, with it's inner workin's...
Old 11-24-2012, 01:26 PM   #3
Good question, but it happens on all of them. When it goes, it breaks loose all at once and the pressure is fine until the next problem.
Old 11-24-2012, 02:48 PM   #4
Is there a balancing valve someplace in the system?
It's also called an antiscald valve.
Thurman (11-24-2012)
Old 11-25-2012, 07:49 AM   #5
no I don't see anything in line.
Tags
water heater flow
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Hot Water Flow kcirtap23 Plumbing 1 02-10-2012 05:11 PM
Hot water pressure problem (unusual situation) tanna Plumbing 2 09-03-2011 09:17 AM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 10:03 AM
