Hot Water Flow - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-18-2013, 12:40 PM   #1
hot water flow
Hi,
Hot water flow in my entire house is slow. When you turn on hot water, it's normal at the begining but it gets very slower.
I flushed water heater once but still same situation.
What should I do?
Thank you.
Ed.
iey514 is offline   Reply With Quote
Old 04-18-2013, 06:45 PM   #2
Lightfoot's Avatar
Rewards Points: 272
try taking the aerators off of each faucet one at a time and flushing the lines out good at full blast. Make sure the screen on back of the aerators are clean before putting them back on. Do same to shower head.
doesn't cost anything to try and it's a cheap fix if that cures it.
Flashlight: A cylindrical container used to store dead batteries
Lightfoot is offline   Reply With Quote
Old 04-18-2013, 08:23 PM   #3
Rewards Points: 14,278
Has it always been slow?
Old steel pipes?
Gate valves on the hot water tank instead of gate valves?
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 02:35 PM
Hot Water Flow kcirtap23 Plumbing 1 02-10-2012 04:11 PM
Tub hot water does not Flow at all (details enclosed) lisaz Plumbing 7 12-17-2008 08:16 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
