Old 08-30-2012, 01:20 PM   #1
Hot water faucet leak in shower
I have a leak from the valve in my shower. I know it is from the hot water when I got a hugh bill. I turned off the breaker for the hot water heater but need to know if there is a way to turn off the valve that would send the hot water to the house. Yes, I am on this a totally unaware female who hasn't a clue. I can't afford a plumber to come untill I catch up my high water bill and can live with cold water just need to know which valve is any to turn off and will it be safe for the water heater being turned off.
flaterrie is offline   Reply With Quote
Old 08-30-2012, 02:54 PM   #2
call me E
TheEplumber's Avatar
Tubs and showers normally do not have shut off valves. But you may get lucky and find some in an access area behind the tub valve-in the wall or under the floor.
Old 08-30-2012, 06:21 PM   #3
Super Moderator
The water shut off for the entire house is usually located at the water meter---sometimes it is part of the water meter.
If you post a couple of pictures we wil be able to offer better help---One of your water meter piping---and one of the shower/tub controls.
Old 08-30-2012, 07:12 PM   #4
Bombastic Idiot
notmrjohn's Avatar
And pic of the water heater, should be a cut off there.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 08-30-2012, 07:38 PM   #5
Since there is usually no shut off to the shower, your choice will be shuuting off all of the water to the house (check near the meter in the baement- if you have a basement or shutting off the hot water to the entire house (check near the water heater). Are you saying that the hot water was running out of the showerhead for a prolonged period and you were unaware of it? It would have to be more than just a small drip if it increased your electric bill so significantly in my opinion.
retired guy 60 is offline   Reply With Quote
Low water pressure in shower Bluew126 Plumbing 5 08-28-2012 07:47 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
How do I adjust hot water limit stop in single handle shower faucet? ThunderCAT Plumbing 2 03-09-2010 03:13 PM
Kitchen Faucet + shower diverter: Need help xtrips Plumbing 1 02-14-2010 04:27 PM
Water leak, over 1 gallon every 5 minutes. carl1864 Plumbing 13 01-15-2010 01:31 PM
