Hot Water Expansion Tank Placement - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-19-2012, 11:43 AM   #1
Hot water expansion tank placement
Does hot water expansion tank connection tee go in front or behind the cut off valve?
CJLJ77 is offline   Reply With Quote
Old 09-19-2012, 10:43 PM   #2
Rewards Points: 1,442
Put the expansion tank on the cold water side between cutoff valve and the water heater.
Old 09-19-2012, 11:22 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
The search function is your friend.
Installation and support of water heater expansion tanks.
Journeyman Plumber
Hot Water Tank Flammable Vapor Sensor Lockout - A.O. Smith - Promax taviyo Plumbing 11 08-14-2013 05:51 PM
Water draining into toilet bowl but not from tank black00 Plumbing 6 09-19-2012 09:28 PM
expansion tank for 40 gal gas water heater amakarevic Plumbing 3 11-03-2011 12:12 PM
Expansion Tank for Tankless Water Heater?? TJ_in_IL Plumbing 3 12-05-2009 01:47 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
