Hot Water Doesn't Last As Long As It Used To. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2012, 09:13 PM   #1
Rewards Points: 398
Hot Water doesn't last as long as it used to.
Our house was built in 2000 and it has the original hot water heater still. Lately it doesn't seem like the hot water is lasting very long. We have a 75 gallon heater and it goes cool before our 50 gallon soaking tub is even half full.
We seem to have enough for showers, although within the last 6 months I've had to inch up the thermostat a few times to keep the water at a normal temp. Right now if the dial is on the "normal" setting the water is only luke warm. Its about 2 notches forward currently.
I tried flushing it out into our Sump since its in the basement but it looked pretty clear from what I could see. I also noticed an old water spot on the concrete about 2 inches in diameter under the pressure release pipe.
Is this a sign of it maybe needing replacing soon? If so, since its 75 gallon and they aren't much more expensive then tankless water heaters, is it worth the switch?? Or should we get a direct replacement?
Thanks in advance
adgjqetuo is offline   Reply With Quote
Old 01-28-2012, 09:17 PM   #2
Rewards Points: 31
Just had same with 2002 hwh. Bad thermostat on one element. Replaced both thermostats and both elements.
ranger12 is offline   Reply With Quote
Old 01-28-2012, 09:19 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
Sounds like the thermocouple that extends into the tank off the gas valve has some calicum build up.
You can drain the tank, remove the gas valve and clean it or simply replace the gas valve. If it is a gas water heater.
If it's electric you may have a bad element.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 01-28-2012, 09:20 PM   #4
Rewards Points: 1,088
Thanks in advance
A tankless model is roughly about the same price as a 75 gal, but the install for that tankless along with the heater itself could reach $3k.
Maybe you should consider a 98 gal tank with high recovery.
http://www.hotwater.com/water-heater...high-recovery/
handy man88 is offline   Reply With Quote
Old 01-28-2012, 09:24 PM   #5
Missouri Bound's Avatar
I'm sorry....I didn't see the part that says gas or electric. If it's electric one of the elements isn't working, either bad element or thermostat issue. Sediment build up can often reach the lower element and cause it to fail.
Old 01-28-2012, 09:27 PM   #6
Rewards Points: 398
Thanks, it is gas.
How expensive are those repairs you mentioned? Is it worth fixing a 13 year old HWH?
Old 01-28-2012, 09:30 PM   #7
Rewards Points: 560
If you have the room you might change out to two 40 gl water heaters (Better Warranty) or better yet go tankless. Never ending hot water.
But with a tankless keep in mind that once a year you need to flush it. It's in the manual but not many retailers tell you that.
The Following 2 Users Say Thank You to Plumber101 For This Useful Post:
adgjqetuo (01-28-2012), plummen (01-28-2012)
Old 01-28-2012, 09:31 PM   #8
13 years is a good life span for a water heater. The very best are usually warranteed for at most 12 years, while most are at 6. Take the opportunity to change it before it becomes a necessity. Tankless gas are OK, but the installation can be costly. Whatever you decide, get 3 quotes before doing anything.....unless you plan on doing it yourself. If you have never flushed it sediment has built up on the bottom making the flame less effective when it fires.
Old 01-28-2012, 09:33 PM   #9
This may be a stupid question, but what is it you flush on a tankless heater? If it doesn't store water why would it need flushing?
Old 01-28-2012, 09:39 PM   #10
Depending where you live water temps coming into tank can be cooler in winter months. This would cool the tank quicker. The thermocouple does not regulate temp only a safty device. Depending on demand and future use I would look into tankless. This only makes sense if it justify the exspense of a tankless. Most of those can be double or triple the cost of the 75 gallon. If you have kids and you plan on staying get one. If it's you and the wife and you plan on moving soon go with the cheaper investment. I try to educate all my customers and let them decide which is the best fit for them. Too bad all those good tax rebates are overwith. Good luck.
plumbbum0203 is offline   Reply With Quote
Old 01-28-2012, 09:41 PM   #11
Tankless have smaller tubing inside like a radiater on a car. These will clog like your heart artery after dinner at KFC
Old 01-28-2012, 09:44 PM   #12
I am of the opinion that unless you need a continuous supply of hot water a tankless water is overkill for almost all situations. And I would never install an electric tankless heater....they are energy hogs.
Old 01-28-2012, 09:45 PM   #13
I understand that. But isn't it flushed every time it is used?
Old 01-28-2012, 09:49 PM   #14
Rewards Points: 560
The imperative still build up just like a tank WH. The heat exchanger on a tankless is small. I'm sure you know this. In areas where water hardness is great and no water softner is used the hardness will clog and I mean completely plug this little heat exchanger.
We use a mixture of distiled water and vinager.
The Sonic here will replace there tankless every year to two years because they won't pay someone to flush it.
The Following User Says Thank You to Plumber101 For This Useful Post:
Missouri Bound (01-28-2012)
Old 01-28-2012, 09:53 PM   #15
Thanks for the expaination....now it makes sense to me. I wonder how many homeowners would do this, or even have it done. Seem like an additional cost which could affect a portion of the savings the tankless claim to provide.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
