Old 10-18-2012, 12:24 PM   #1
Hot water and crossed valve issues
So I recently moved into a new house and I have realizing that in the master bathroom the sink is backwards, you have to turn the left one on for cold and right for hot. Also, when I hooked up the washer I realized that they messed up there, I have to switch the hoses in order to get it right.
Secondly, the half bathroom downstairs and the washer are the closest things to the water heater, like within 3 feet, they get REALLY hot water like instantly. When it comes to the kitchen and the upstairs bathrooms it takes awhile to warm up and even with them all the way to hot, they only get warm, not really "HOT."
Does anyone have any ideas or suggestions? Could the crossed valves or whatever it maybe have anything to do with why the water won't get hot enough in the other locations? I have checked the water heater and it is on the HOTTEST setting it can be on, as well as lighting properly when I look through the little inspection window. Any suggestions or ideas would be really helpful, I really want HOT water upstairs!
Thanks a lot,
Zach
mckain87 is offline   Reply With Quote
Old 10-18-2012, 12:48 PM   #2
Experienced
Jackofall1's Avatar
Hello and Welcome Zach, to the best darn DIY'r site on the web.
As for the reverse plumbing not to hard to fix, just change out the hose or tubing the faucets.
As for hot water cooling down, how far away is the furthest faucet. If the pipes aren't insulated they can lose alot of heat from the HW tank to the point of use.
Mark
Old 10-18-2012, 01:29 PM   #3
They are upstairs. Maybe 35 feet from the water heater. I didn't know if maybe I needed a "beefier" water heater. I do not know about the pipes...wouldn't even know where to look to check if they are. Maybe have a plumber come look?
Old 10-18-2012, 01:32 PM   #4
Experienced
Jackofall1's Avatar
Changing the tank will not change the heat loss characteristics of the piping, the only thing that will do that is insulating the piping. The insulation is usually either black or grey.
tiling deck of a 5 ft corner tub level with tub deck Blue Falcon Carpentry 16 09-28-2011 01:55 PM
Hot water problem - Figured out cause - Need advice how to fix! kissiffer4 Plumbing 68 04-03-2011 02:22 AM
Need to ID Gate Valve (Please Help) MikeGV Plumbing 3 10-04-2010 12:02 PM
Bleeding air - Hot Water Boiler Dragon HVAC 10 10-30-2006 09:13 AM
