Hot Water On Cold Water Side - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-24-2010, 04:18 PM   #1
why am i getting hot water on the cold water side of my sinks
Im getting hot water on both sides of my faucets and i cant figure out why
castro is offline   Reply With Quote
Old 08-24-2010, 04:48 PM   #2
Civil Engineer
Rewards Points: 4,940
This will happen if the hot water line under the sink is connected to the cold water side of your faucet.
Old 08-24-2010, 05:49 PM   #3
Rewards Points: 1,548
1. Shower faucets were left on and the shower was shut off at the shower head. Hot water crossed over to the cold pipe that way.
1a. A similar defect exists in your washing machine water inlet mechanism. (OT: The wall faucets to the washing machine should be shut off between washes which will also cure the topic of this thread. A leading reason for flood insurance claims is broken or burst washing machine hoses.)
2. Your water heater does not have an expansion tank and as the next tankful was heated, it expanded pushing back through the cold water lines.
3. The cold water line runs very close to the hot water line over some distance or runs through a radiant heated concrete floor slab.
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 09:16 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Pluming Hot Water Turning Cold - Help! kissiffer4 Off Topic 1 01-14-2010 05:00 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
can't shut off cold water from main disconnect DanBress Plumbing 3 01-06-2008 06:20 PM
